General Module 3 : 1998 740 iL - BMW Forum - BimmerWerkz.com
Old 06-08-2011, 11:35 AM   #1 (permalink)
Car: 740 iL
stilllearning6 is on a distinguished road
I believe that my 1998 740 iL General Module 3 might be fried and /or might be causing a battery drain.
Symptoms include lacking: rear P/W, central lock, soft close/ open trunk,interior lights, glove light ,trunk 2 lights.
I am considering trying to pull the GM3 from behind the glovebox.
I read that there are 3 cables to disconnect .
If I pull the GM3 , will the car still drive ?
stilllearning6 is offline   Reply With Quote
Old 06-08-2011, 01:51 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
You really should stay with your original post on this subject, buddy...
Multiple posting on the same subject will just confuse people that are trying to help you sort your problems.
DAZ
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 06-09-2011, 06:01 AM   #3 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
I don't know for sure if it will still drive, but I read that the power steering also has an input from the GMIII in the form of a solenoide. I think that you are right that there are 3 connectors on it
Riding in style
Old 06-11-2011, 07:11 AM   #4 (permalink)
Car: 740 iL
Gemeral Module removed
My experience with 1998 740 iL was that the GM3 could be removed w/o removing glovebox.
I learned that my GM3 was held in place on each left and right side by a hidden hook/ tab/ release clip .
I could not see this holding mechanism untilI disconnected the wiring cable closest to the center of the vehicle.
This is the white plastic far end , not the wider black plastic connector end.
Mine required to pry the white "hook/tab/release clip " outward away from the GM3 .
Then , I could wiggle the GM3 out .
Perhaps others will benefit from this tidbit.
The glovebox was merely opened wide and pulled upward.
Old 06-11-2011, 07:53 AM   #5 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Good post matey... Was the GM3 your problem?
DAZ
Eso es todo!
BMW Part Market
New Member ?
Old 06-12-2011, 08:07 AM   #6 (permalink)
Car: 740 iL
Hope to isolate the issue by Monday PM .
Thanks to all for input and guidance .
I am not used to working on BMW 's , my wrenching experience is on 1988 Jeep Wrangler with feedback carburetor and 30 miles of vacuum tubing and more emission equipment than I could ever imagine.
Old 06-12-2011, 08:48 AM   #7 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Yeah, Carb's and Injection systems are two different worlds mate !!!
I feel for you, honest !
Eso es todo!
BMW Part Market
New Member ?
Old 06-14-2011, 05:38 PM   #8 (permalink)
Car: 740 iL
GM3 back to life , why ?
Installed Autozone 49 - DL battery after a 48 hour trickle charge on the new battery .
Replaced original " fried " GM3 and all lost functions came back to life.
I can not explain the reason .
Previous battery ( 7 and half year old AutoZone 49 -DL ) was fully trickle charged and measured FULL . Swapped battery on advice of dealer techs.
Perhaps others may benefit from my experience .
Very General Question? Peter23 3-Series (E36) 27 10-24-2008 11:38 PM
General Lee Vs Me fast 6 Driving Tales 19 09-15-2005 11:18 AM
Need Some General Advice. thesoprano M-Series (M1, M3, M5, M6) 2 08-19-2005 02:08 AM
General Control Module question wilkie3 5-Series (E12,E28, E34, E39, E60) 0 08-04-2004 11:27 AM
1998 E46 General Conrol Unit Raptor 90 3-Series (E46, E90) 2 05-24-2004 12:51 PM
