front end clunk noise - BMW Forum - BimmerWerkz.com
Old 04-20-2004, 11:48 PM   #1 (permalink)
ronaldo is an unknown quantity at this point
hello everyone....
i bought my cr about a week ago (in sig) and i am very hapy with it so far. i got it for $25k with 63k miles. but, i noticed when going through small potholes or over bumps that there is a clunking noise coming from the right front wheel. i was thinking maybe it is a control arm bushing, tie rod bushing, or something of the sort. is this a common 7 series problem? and what is the most common thing that is worn out or 'broken'? thanks! i didnt have the time today to look under it because i got home from work after dark. thanks!
<img src='http://www.evolvefish.com/fish/media/MA-AWOL.jpg' border='0' alt='user posted image' /><img src='http://www.hosstyle.com/Goofy%20shit/Goofyshit36/images/likearockonlydumber-big.jpg' border='0' alt='user posted image' />
ronaldo is offline   Reply With Quote
Old 04-21-2004, 02:31 AM   #2 (permalink)
shifty's Avatar
shifty is an unknown quantity at this point
Send a message via AIM to shifty
It's most likely a bushing yeah. Check the lower control arm. I've already changed my bushings on both sides, including the rear that developed a spring squeak. This is a normal problem that develops on any car with higher milage that hasnt had the suspension serviced. Not too expensive to fix tho, if you're willing to do the labor yourself.
<img src='http://shifta.servebeer.com:8080/sig.gif' border='0' alt='user posted image' />
shifty is offline   Reply With Quote
Old 04-21-2004, 10:30 AM   #3 (permalink)
ok... that is what i thought it would be. the car has a warranty from where i bought it from, but they most likely wont cover this. thanks!
Old 04-21-2004, 01:15 PM   #4 (permalink)
shifty's Avatar
you also might want to check the strut mount bushings.
Front End Noise meditek 5-Series (E12,E28, E34, E39, E60) 9 05-31-2005 01:20 PM
Front Suspention Noise theruss1an1 3-Series (E36) 5 01-24-2005 04:12 PM
Noise From Front Of Engine At Startup! jesse91911 3-Series (E46, E90) 6 10-17-2004 12:23 AM
front end noise fushuman 3-Series (E36) 4 09-20-2004 04:21 PM
noise out of front and rear driver's wheels debbie M-Series (M1, M3, M5, M6) 5 11-22-2003 05:25 AM
