i recently bought a 95 bmw 740i. it has an aftermarket LPG-g3 lpi installation in it.
when i bought the car it already didnt sound nice but i thought it would be an easy fix.(but its not i guess)
when the engine is cold (after 8 hours) it starts direct but sounds like it runs on 5 or 6 cilinders. then when its hot when i turn the key it takes about 10 seconds before it starts.. still only 5 to 6 cilinders..
i dont know if the lpg has anything to do with it. it runs just the same on gasoline as it does on lpg.
the dealer has looked for any fault codes but it doesnt have any??
anyone has a suggestion?
im getting a new CPS in a day or 2.. but dont think this will fix it.
also the car just died after startup this morning.. tried it a couple of times. the rpm stays around 400..
It could be your MAF, but that would show a code, I would say its to do with the LPG system, I have come across a lot of problems conerning 5 & 7 series with an LPG system fitted, your best option would be to take it to an LPG service centre. However if there's a way to isolate the LPG try that first.
Hmmm... I know its not what you want to hear but LPG and V8's just don't go together, get rid of the gas then with help from here she will run as she should...she never will on gas....or should I say may for a while...
It was designed by engineers to run on petrol not gas...I will say no more, apart from don't buy a V8 and then worry about the running costs !!! false economy?
Did the previous owner give you any insight into the history of the problem?
Have you looked at the spark plugs to establish if it is consistent in which cylinders are not firing, it might have something to do with the iginition system if two or three of the plugs are showing signs of being unignited. Given that the problem is consistant on LPG and Petrol, I'd look at the common systems first, plugs, leads & HV packs.
i got some details from the last owner but i dont believe the bills he gave me ar from this car.. i have a bill of 4 new spark plugs.. seems kinda weard on a 8 cil car..
but tomorrow i wil have a look at the sparkplugs and i will look if i can check the MAF..
iim thinking to just dissconnect the MAF when its running to see if te computer does indeed detect the faults..
i
thanks for all the help and tips you guys have given me
I am not sure if it applies to the more modern injected LPG conversions, but the old mixer style units required a different spark plug to the petrol only engines, so it may be worth checking that the "correct" plugs are installed.
i have now changed the CPS.. the car doesnt die anymore but still it doesnt run smooth..
the RPM shakes around 400 to 600.
i also disconnected the MAF while the engine was running.. the engine didnt change in rpm. also no check engine lights came on..
it seems it doesnt respond to any errors at all
i also did the obd test nr.2 to check all the lights in the dash.. the check engine light doesnt work?? is this normal ? all the other ones work in the test..
i also got 8 new NGK spark plugs..
i think i will fit them tomorrow to see if there is any improvement.
At this point I would have a diagnostics done, as it sounds like someone has messed with check engine light or it has burnt out like Brettski has mentioned, when the MAF is unplugged it should run like a pig...it maybe that its on 02 sensor, diagnostics would put you in the right direction or you could be messing about for ages and spending money on parts that are not required.
Where do you live as Ive just notice you had "getriebenotprogramm" come up are you in Germany?, the reason I ask is that older european 7 series dont have the EML light fitted!!
Ok, The SES light indicates an engine fault that will cause raised emmisions, such has a misfire, air-leak etc. In certain countries it is called the OBD (On Board Diagnostics) indicator and has the same function as the SES light. If it doesnt come on then you dont have a problem with the above...
What I would do next is clean the throttle body and MAF, also for any air leaks even though the light is not on,,,there is a gasket that sometimes fails between the throttle body and intake manifold check this if its hard or cracked it will let air in the system..
