drivetrain swap dilemma M60 3.0 flywheel to 4.0 litre - BMW Forum - BimmerWerkz.com
Old 12-08-2011, 04:09 PM   #1 (permalink)
trblcumn is on a distinguished road
can the trans. bellhousing and flywheel interchange between the two 3.0 and 4.0 M60 engines? before I make another costly mistake
trblcumn is offline   Reply With Quote
Old 12-09-2011, 11:27 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
As they both use the same block then why not... Your issue might be the actual gear-ratios vs diff-ratio...
Having said this do a search using BMW M60, click the wikipedia listing and pay particular interest in this line...
"The M60 was offered in two sizes: the 3.0 L M60B30 and the 4.0 L M60B40. The two had very similar design, but neither block, heads, nor crankshaft were interchangeable."
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 12-09-2011, 08:36 PM   #3 (permalink)
thanks, I see now the engine is internally balanced so swapping flywheels should work. I started pulling the trans today and the last bolt to loosen was ground down [starter motor] I guess they junked the car just for a stripped hex head. I`m drilling it out and stoked to be rid of that automatic
Old 12-10-2011, 01:14 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
So your plan will work eh?
Eso es todo!
BMW Part Market
New Member ?
HSV W427 - 7.0 litre V8, 500hp the M5 Competitor! abupu 5-Series (E12,E28, E34, E39, E60) 0 06-20-2008 03:10 AM
M3 Drivetrain Swap Black528i M-Series (M1, M3, M5, M6) 2 12-09-2004 11:29 AM
E46 3.0 litre engine transplant 3MSW 3-Series (E21, E30) 6 07-31-2004 09:29 PM
Flywheel dilemma M3Daemon 3-Series (E36) 6 03-28-2004 02:15 PM
2.Litre power problem Herbs 3-Series (E46, E90) 0 10-03-2003 04:38 PM
