Door locks won't lock - BMW Forum - BimmerWerkz.com
Old 10-24-2006, 09:15 AM   #1 (permalink)
fast 7's Avatar
Car: 1988 735i
fast 7 is an unknown quantity at this point
I have an 1988 e32 and my door locks won't lock with the key. If you try to lock the doors The driver side lock will pop up after one try and then will stay down, but it will not lock any of the other doors. If yo utry to lock it for mthe passenger side it does nothing same as the trunk. Have to manually lock all the doors. When yo uunlock with the key they all unlock like normal. Is the door lock controler bad or are teh locks out of sink? Can i put them back into sink? Thanks.
fast 7 is offline   Reply With Quote
Old 10-24-2006, 09:49 AM   #2 (permalink)
Door locks
Again, Johan & Sean's E32 Page for a sloution.
These cars as they age have issues with the door lock solenoid support bracket cracking and allowing the solenoid assembley to get out of alignment. I had to take the door panel off and weld the bracket to realign thnigs.
Old 10-24-2006, 01:19 PM   #3 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Bear, thanks for sharing your finding with the rest of us!
LOS
Front passenger door lock da_bull 5-Series (E12,E28, E34, E39, E60) 2 05-20-2006 10:45 PM
Broken Door Lock Driver Side, 318i SquireOne 3-Series (E21, E30) 1 03-03-2005 03:06 PM
Driver Side Door Lock Getting Stubborn ultraviolet353 3-Series (E36) 8 01-15-2005 07:37 PM
Problem With The Lock On The Trunk uclabruins1996 3-Series (E36) 4 12-17-2004 01:29 PM
Bmw Ignition Lock & Steering Lock Powersuction 3-Series (E36) 1 09-22-2004 11:56 AM
