Cranks but no start - BMW Forum - BimmerWerkz.com
Old 10-23-2008, 12:52 PM   #1 (permalink)
Queball is on a distinguished road
Unhappy Cranks but no start
HELP, I have a 91 750IL that turns over but won't start. By searching and reading online I found this board. Now a little background, My old girl doesn't like to sit after about 2 weeks I thought I would take her for a spin with no luck. I have check the fuel pumps, Timing chain & All the fuses. Is there a way to test the relays or are they just an R & R item? Thanks in advance
Queball is offline   Reply With Quote
Old 10-23-2008, 01:31 PM   #2 (permalink)
kandi08's Avatar
Car: 1993 E36 318is Coupe M Sport
kandi08 is on a distinguished road
Alright mate.
Have you got a spark?
Relay should tick noisey, if it's not working.
Sound's like no spark.
kandi08 is offline   Reply With Quote
Old 10-23-2008, 02:23 PM   #3 (permalink)
84bmw318i's Avatar
Car: 91' 318ic
84bmw318i is on a distinguished road
Send a message via AIM to 84bmw318i
same thing happened to me and it turned out that the alternator broke inside the distributor cap.
84bmw318i is offline   Reply With Quote
Old 10-24-2008, 09:57 AM   #4 (permalink)
No start
Haven't checked that yet, It's next on my list along with checking the crank position sensors. The cap and rotors like really good.
Old 10-24-2008, 12:30 PM   #5 (permalink)
I just checked, I do have spark. I guess the next is to check fuel pressure?
Old 10-24-2008, 12:38 PM   #6 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Try this it also applies to the 750:
Board Message
Ps. Im a member here its only for 7's worth being a member its free.
Old 10-25-2008, 08:46 PM   #7 (permalink)
I tried the information from this post, It does appear that it was flooded. I did get it started, But now it doesn't want to idle and seems like it is fuel starved. It will run up to about 2500 rpm then die.
Old 10-26-2008, 04:07 PM   #8 (permalink)
marti5's Avatar
Maf sensor???. take it off if it runs the same thats the problem, if so only replace with genuine BMW. Do NOT buy a cheap one they measure the air intake incorrect and just dont work.
Old 10-26-2008, 05:04 PM   #9 (permalink)
Do I pull both units off, Or just 1 bank? Can they just be disconnected.
Old 10-28-2008, 07:21 PM   #10 (permalink)
Thanks for all the help, My old girl is up and running. I did just pull 2 codes from it though, Code 10 (Camshaft/cylinder ID sensor), & Code 52 (Engine drag torque control MSR)
Old 10-30-2008, 07:15 AM   #11 (permalink)
marti5's Avatar
Ok, You would be wise to replace the camshaft sensor if its brought it up, what I would do is run it for a 100 miles or so and see how she goes, then do a diagnostic again, if it comes up again change it or you will only have problems later on.
90' 525i cranks...won't start...HELP!!!! urai4m 5-Series (E12,E28, E34, E39, E60) 2 05-07-2008 01:28 PM
Engine cranks but wont start .:[[I have searched for days now]]:. rote36bmw 3-Series (E36) 2 01-16-2007 10:15 PM
My car cranks, but won't start?! MarqE36 3-Series (E36) 19 05-01-2006 10:27 PM
Motor Cranks But Wont Start AllEyezOnMe 3-Series (E36) 4 11-22-2004 12:16 PM
Car cranks but doesn't start silver325rider 3-Series (E36) 9 07-13-2004 11:47 PM
