Coolant Leakage - 1998 740i - BMW Forum - BimmerWerkz.com
Old 08-13-2004, 04:13 AM   #1 (permalink)
gm3mtm is an unknown quantity at this point
I have some coolant leaking from the engine it is droping out of the rear side of the engine. The hoses feeding to the water control valve and the valve itself have recently been replaced. Anything else that might be causing this?
Thanks!!
gm3mtm is offline   Reply With Quote
Old 08-13-2004, 07:40 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
The right side of the engine looking which way... ???
The right side as if you were sitting in the drivers seat???? or the right side looking towards the rear with the hood up???....
1997 E36 M3 1990 E30 325i
Old 08-13-2004, 12:47 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
Look up inside the bolt holes in the bell housing, if you have coolant residue there then you may have a leaking "belly pan" which is on top of the block in between to 2 cylinder heads. Intake manifold must be removed to replace it.
DT
Old 08-13-2004, 03:35 PM   #4 (permalink)
Make sure all of the hose clamps on the auxiliary and heater hoses are tight, check below the expansion tank for leaks as well.
1998 740i Fully Loaded: $13500 Obo!!! Sean@Jlevi SW Classifieds Sell & Buy 1 03-20-2005 06:01 PM
White Smoke - 740i 1998 gm3mtm 1,6,7,8 - Series and Mini Cooper 2 10-01-2004 08:13 AM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 09:48 AM
7 Series Heat Stays On - 1998 740i gm3mtm 1,6,7,8 - Series and Mini Cooper 1 05-31-2004 12:57 PM
Changing the coolant on 1995 740i deadseasquirrels 1,6,7,8 - Series and Mini Cooper 4 02-02-2004 06:35 PM
