cold start engine knock and tap... help - BMW Forum - BimmerWerkz.com
Old 01-16-2012, 12:24 AM   #1 (permalink)
THIRDGEN87's Avatar
Car: 2000 740i Sport E38
THIRDGEN87 is on a distinguished road
ok guys. im lost on this one. the coldest night here in nj all year. temp is 25. i go outside and start my car. vanos and a tap knock sound while car is running. ses light came on right away. plugged in my mac obd2 reader and got codes p1519 , p0325 , p1175. i looked up all these codes and know what they mean. but does anyone know, or have had experience with the similar codes all at once. p1519= cam position actuator , p0325= knock sensor , p1175= fuel trim actuator. just tring to figure out what needs to be done or changed. my car always had the vanos noise. now its just a little louder. sound seems to be coming from the passenger side. thanks for your help / knowledge in advance
2000 740I SPORT
THIRDGEN87 is offline   Reply With Quote
Old 01-16-2012, 12:40 AM   #2 (permalink)
Are you using a good winter oil?
Old 01-16-2012, 08:45 AM   #3 (permalink)
THIRDGEN87's Avatar
honestly, i dont know what is in there since i just bought the car. but i do know it is full synthetic. last oil change was done by a reputable local indy. he is a certified bmw tech. i know this by the sticker on the windsheild. but it isnt due for another 1900mi. should there be a different weight. and would this cause the car to run rich and knock? thank you.
2000 740I SPORT
Old 01-16-2012, 12:53 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Mine does it to be honest, but I know it's the oil (which I need to change as a matter of urgency LOL)...
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 01-16-2012, 01:08 PM   #5 (permalink)
THIRDGEN87's Avatar
ok update. drove car for 30min. hooked up code reader. getting 6 codes. cps actuator bank 1, multiple misfire cyl 1, 2, 4 and knock sensor.
2000 740I SPORT
Old 01-18-2012, 01:05 PM   #6 (permalink)
jimmythepie's Avatar
Car: 98,328i
any update on this story?
jimmythepie is offline   Reply With Quote
Old 01-18-2012, 06:15 PM   #7 (permalink)
Car: 96 318is chipped M3 exh
inc_ride2 is on a distinguished road
Okay Misfires are ignitions coils thats are bad, if you chnage them out also change the plugs... As far as oil I would ask my person that chnaged the oil what weight was used, also double check the oil level.
inc_ride2 is offline   Reply With Quote
Old 05-23-2012, 10:59 PM   #8 (permalink)
Car: 2001 740il
bricha2 is on a distinguished road
I had the same problem. It's your front intake gasket... See item 11 below....
bricha2 is offline   Reply With Quote
2004 545i engine shaking on cold start fanling New Members Check In 2 01-15-2011 10:55 PM
525i rough engine running after start in cold weather azfarkas 5-Series (E12,E28, E34, E39, E60) 0 03-02-2010 08:15 AM
Bad Engine Start 320d 2002 no matter cold or hot greenironfist 3-Series (E46, E90) 3 05-26-2009 04:20 PM
'01 530i engine knock lotsacars 5-Series (E12,E28, E34, E39, E60) 12 11-17-2005 06:15 AM
Engine Ping When First Start Engine Cold mikes325is 3-Series (E36) 0 09-29-2004 06:12 PM
