Changing Oil On 94 740il - BMW Forum - BimmerWerkz.com
Old 01-09-2005, 05:28 PM   #1 (permalink)
dejectedgeek is an unknown quantity at this point
Can anyone help me out with instructions on how to change the oil filter in a 1994 BMW 740iL? Thanks.
dejectedgeek is offline   Reply With Quote
Old 01-09-2005, 07:03 PM   #2 (permalink)
TECH's Avatar
[snapback]267625[/snapback]
The filter is an element type, not a spin-on. It's taken off from the top, in the front of the engine. The metal housing has a black top, and you need a 36mm socket to screw it off. The element is changed as well as the big o-ring on the cap. Tighten snug, the torque is on the cap, if you wish to torque it.
Old 01-19-2005, 06:33 PM   #3 (permalink)
True. cne caution, some of these 1994s had a cannister with a plastic top and some with a metal top and the oil filter is a bit different as the hole in the center of the filter is a different size based on wheter the cannister has a plastic or metal top.
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
spark plug drenched in oil Beemerguru 3-Series (E36) 2 10-06-2005 10:06 PM
