Changing the battry - BMW Forum - BimmerWerkz.com
Old 02-06-2004, 08:31 PM   #1 (permalink)
car34 is an unknown quantity at this point
How do you get the back seat out of a 740i to change the battery? Also if you disconnect the battery will the computer lose the codes from a check engine light? ghead
car34 is offline   Reply With Quote
Old 02-08-2004, 12:57 PM   #2 (permalink)
EXtech's Avatar
just yank up on the front of the seat.
Sometimes it will clear the light, so long as there is not a current issue to cause a check engine light to re-illuminate. You can also touch the positive and negative battery cable together for 10 sec (AFTER THE BATTERY IS DISCONNECTED AND REMOVED)
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Changing parkinglights on 2001 325xi CWO4NavyRetired 3-Series (E46, E90) 1 10-26-2005 03:29 AM
Is It Bad To Just Changing The Spring? E46speedking 3-Series (E46, E90) 1 10-13-2004 07:08 AM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 09:12 PM
