can some one help me - BMW Forum - BimmerWerkz.com
post #1 of 21 (permalink) Old 02-21-2008, 07:24 PM Thread Starter
revharde30 is on a distinguished road
my 735il 92 model will not charge i put a new alternator and batery and still wont charge please help
revharde30 is offline
post #2 of 21 (permalink) Old 02-21-2008, 11:09 PM
Sodium Chloride
saltshaker185's Avatar
saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold
what do you mean it wont charge? as in the car wont start? it doesnt have enough power to start? or the battery just dead after it runs out of juice?
saltshaker185 is offline
post #3 of 21 (permalink) Old 02-22-2008, 02:04 AM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
the alternator is not charging the battery.... still looking into the regulator....
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #4 of 21 (permalink) Old 02-22-2008, 06:11 AM Thread Starter
yeah i put a meter on back of the alternator no charge coming out
post #5 of 21 (permalink) Old 02-22-2008, 06:41 AM
I am Teh Edumacator.
Teh Prof's Avatar
Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of Teh Prof has much to be proud of
You replaced the alternator, the alternator is still spinning with the belts, you tested the alternator terminals during vehicle operation, and no voltage? Sounds like you replaced a bad alternator with a bad alternator.
Lindsay fan club member.
Teh Prof is offline
post #6 of 21 (permalink) Old 02-22-2008, 03:51 PM Thread Starter
i got the alternator from autozone when i took the first one off and took it and got it tested they said it was good but i went ahead and bought it anyways are they somthing in the car that makes it charge like a relay
post #7 of 21 (permalink) Old 02-22-2008, 05:05 PM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
perhaps a bad input to the alternator, maybe a bad D+ connection or a bad ground.
DT
Dirty_Tool is offline
post #8 of 21 (permalink) Old 02-22-2008, 07:59 PM Thread Starter
how would i check to c if thats bad
post #9 of 21 (permalink) Old 02-23-2008, 11:33 AM
Moderator
Dirty_Tool's Avatar
you need to use a multimeter at the back of the alternator with everything connected check voltages at the large post with red wire (B+) as well as the small post (D+) You should have over 12v at each terminal. Change the meter setting to ohms and check betwen the case of the alternator and 1 of the bolts on the shocktower. You should have less than 1 ohm. Report back with results.
DT
post #10 of 21 (permalink) Old 02-23-2008, 05:20 PM Thread Starter
its got 11.21 but the belt is kinda loose would that be the problem and its got 1 ohm
post #11 of 21 (permalink) Old 02-24-2008, 11:49 AM
Moderator
Dirty_Tool's Avatar
11.21 at BOTH the thicker wire (B+) and the thinner wire (D+) at the back of the alternator?
is this measurement taken with engine running or not running?
does the battery light in the dash illuminate?
DT
post #12 of 21 (permalink) Old 02-24-2008, 04:24 PM Thread Starter
11.66 on big abd 10.65 onlittle as engines running tightened u[ the belt it didnt help and no the batery light is not on so any ideas yet
post #13 of 21 (permalink) Old 02-24-2008, 09:21 PM
Moderator
Dirty_Tool's Avatar
sounds like you have everything you need for the alternator to work... Id try another alternator. Also charge the battery ..
Regards,
DT
post #14 of 21 (permalink) Old 02-24-2008, 11:02 PM Thread Starter
but it is a brand new alternator
post #15 of 21 (permalink) Old 02-24-2008, 11:40 PM
Moderator
Dirty_Tool's Avatar
your alternator needs three things in order to charge.
1) power at B+ which is the big positive wire coming from starter
2) power at the D+ wire also referred to as an exciter wire which is the smaller wire which goes through the instrument cluster and feeds the back of the alternator on the smaller eyelet
3) ground.
We checked all of those things so unless you made a mistake in your measurements then it sounds like a bad alternator. Of course I'm not standing in front of the car so all I can do is make suggestions. I dont know much about autozone alternators because I only use facotry parts for BMW but years ago I used to buy alternators from Kragen and had terrible luck.. one time i purchased 4 alternators before I got a good one.
DT
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 1,6,7,8 - Series and Mini Cooper
