Can low oil pressure from valve cover create an engine knock??? - BMW Forum - BimmerWerkz.com
Old 02-02-2010, 01:11 PM   #1 (permalink)
JohnU's Avatar
Car: 91 750il grey and lil beat down.
JohnU is on a distinguished road
A buddy of mine was going to "help me out this past weekend" with some minor noise issues and had the whole top end of the motor off to clean intake manifolds, injectors, and oil port tubes tubes that I suspected were in mucked up a bit and turned out yes a few holes were plugged.
I had a slight valve tick. Not real bad but figured better safe than sorry right? Well The IDIOT!! Didnt put new valve cover gaskets back on before re-assembly he used that gasket maker crap!. Trying to save me $60. GRRRRRR. Leaks like niagra falls and knocks.
Can the "knock" be from low oil pressure due to this gasket issue? Seems like it would to me but would like definite confirmation if possible.
When running the "tick" I was trying to fix seems to be gone but there is this knock now and I cant really hear to well due to the splashes of oil hitting the ground LOL. Either way I will be putting new gaskets back in this weekend.
Thanks
JohnU is offline   Reply With Quote
Old 02-02-2010, 07:36 PM   #2 (permalink)
Car: 1990 BMW 735iL
beamers4life is on a distinguished road
Yeah man these engines are super high compression engines and will just blow that gasket maker shit out. Knock could be that gasket maker ended up in an oil port and clogged it back up and now a rocker arm or valve is running completely dry. Or maybe a valve just needs a feeler gauge and adjustment. Wouldnt run it until you got new head gaskets buddy. Ive got a 1990 735il and ive got a tick as well. I bet your 12 cylinder will fly though. Keep us posted
beamers4life
beamers4life is offline   Reply With Quote
Old 02-07-2010, 03:36 PM   #3 (permalink)
joshydt58's Avatar
Car: 2001 740i sport
joshydt58 is on a distinguished road
i have a 01 740 and a slight oil leak around the heads. when i start the car i can hear the lifters making a little noise after start up but once its ran for a sec it goes away. i figure the oil leaks out while sitting then fills back up once the engine starts. im planning on changing mine once i get a little better weather.
joshydt58 is offline   Reply With Quote
Old 02-07-2010, 09:33 PM   #4 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
^ change your valve covers to fix the leak BUT the tick on start up is a known m62 issue I would up the oil weight
1992 318i Coupe parts car
I am Captain Obvious
Old 02-08-2010, 02:58 AM   #5 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
So in your opinion, what oil should be used in the M62 & M62TU engines?
Old 02-08-2010, 10:23 AM   #6 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
10w/40, These engines normally tick as the hydraulic tappets get sticky due to a lot of start/stop small trips, they are after designed for motorways/highways and not poodling around town in, get the gaskets on the covers dne and give it a good 80mph run down the Highway.....the other reason for a tick is the Vanos unit...seals
Old 02-08-2010, 11:12 AM   #7 (permalink)
^ yep! I use 15w50 in the 740il
I will be switching to 20w40 though (Full syn. of course)
Old 02-08-2010, 01:10 PM   #8 (permalink)
joshydt58's Avatar
thanks for the pointer. i had no idea and have just been taking my car to tires plus or midas for a oil change.
STOP! engine oil pressure? kc740i 1,6,7,8 - Series and Mini Cooper 3 03-21-2010 02:37 PM
Low Oil Pressure Message DonJ 5-Series (E12,E28, E34, E39, E60) 6 09-04-2009 09:05 PM
Ventilation Valve Pressure Regulating Valve /Oil Separator jaguar52662 5-Series (E12,E28, E34, E39, E60) 2 02-02-2009 09:03 PM
Panic! Low Oil Pressure Warning. 540i meditek 5-Series (E12,E28, E34, E39, E60) 2 05-02-2005 12:24 PM
Low Oil Pressure silverjay 3-Series (E36) 2 10-15-2004 08:05 AM
