BING...Brake Light - BMW Forum - BimmerWerkz.com
Old 11-09-2009, 11:59 AM   #1 (permalink)
BigT's93's Avatar
Car: '93 740IL,
BigT's93 is on a distinguished road
BING...Brake Light
I put a new brake light bulb in, now it's, Bing....Brake Light.
Before I think about a new sensor.... where exctly do I " sand paper teh connectors"? Some random bimmer driver suggested it.
I have taken bulb holder out and hit it and everywhere the holder might make contact w/ s-paper. Any suggestions?
Uhhh...if the universe is still expanding, WTF is it expanding into?
BigT's93 is offline   Reply With Quote
Old 11-09-2009, 11:27 PM   #2 (permalink)
Car: 1990 BMW 735iL
beamers4life is on a distinguished road
I have a 1990 735 il and had the same problem pull the brake light bulb and socket out(1/4 turn about) inspect the two contacts on the socket and see if they are both there and whether or not they are bent back. Afther that inspect the hole where the socket came out of and see if they are both there and whether or not they are corroded(leaky trunk possible?) After that if it still doest work take your volt meter and test the points to see if you are getting enough voltage to the socket. Have you checked the fuse under the hood? Have you checked relays in the fusebox under the hood?
post back and i can help you some more
beamers4life is offline   Reply With Quote
Old 11-10-2009, 06:12 AM   #3 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Might be a silly question, but do all of your brake lights actually work even though the warning light says that they aren't? Have you replaced the failed bulb with the right wattage bulb?Was the original bulb blown or just not working?
Old 11-10-2009, 10:02 AM   #4 (permalink)
BigT's93's Avatar
Car: '93 740IL,
BEAMERS4LIFE,
Good info, will run thru check list.
Brettski,
I've learned no questions are silly. Original bulb was blown...and I can only hope my local
Autozone had the correct bulbs in the box. I did make sure the vendor # matched his computer info.
The new bulb was working, but when ‘bing’ came on I would tap the brake light cover and it would come back on. Now, nothing, 'bing' is in full effect and no brake light. This issue finally got on my nerves enough to ask for help, which is greatly appreciated.
Let me try the “fixes” and thanks again.
Old 11-10-2009, 10:13 AM   #5 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I would say its bad contacts on the cluster....sand paper is the answer...
Old 11-10-2009, 10:34 AM   #6 (permalink)
Car: 1990 BMW 735iL
yeah it sounds like the contacts do your voltmeter test and figure out what your getting from those two contacts. If its less than 11.4 or so then your contacts are corroded or you have a ground problem. If its zero then you have a short or a fuse or relay issue
Old 11-11-2009, 03:57 PM   #7 (permalink)
BigT's93's Avatar
Car: '93 740IL,
Well, I had a modest amount of success. Passenger side brake light now working. Driver side still out. Deffo heading in the right direction. NO volt meter testing done, will have to wait until weekend if a little more sanding won't cure.
Thanks!!!
Old 11-11-2009, 09:58 PM   #8 (permalink)
Car: 1990 BMW 735iL
yep sounds like contacts are your issue buddy keep us posted. just remember thought if the contacts are bent back then they still wont make contact even if you have sanded them. Also in the fusebox pull out the yellow mustard colored relay and inspect the protruding contacts do they seem slightly burnt at all if not then put it back in. It is either one or the other from here out.
Old 11-13-2009, 04:48 PM   #9 (permalink)
BigT's93's Avatar
Car: '93 740IL,
Well, I pulled the above relay and yes there is a not so pretty brownish burn mark. I may go pull the one from my parts car and replace. Hope that fixes it, if not I'll be back.
Old 11-17-2009, 11:29 PM   #10 (permalink)
Car: 1990 BMW 735iL
Sounds like a problem if not the problem. Keep us posted.
Old 11-18-2009, 09:11 AM   #11 (permalink)
BigT's93's Avatar
Car: '93 740IL,
Could not get to my bro'in'laws to access my parts car. I honestly dont know if replacing
one old relay w/ another will work. I can have b-in-law's mech take a quick look at it.
One way or the other I'll work it out. Thanks to all.
That is All...
Old 08-08-2010, 07:19 PM   #12 (permalink)
Car: BMW 730i V8 - Calypsorot - E32
Sarot is on a distinguished road
I have the exact same problem with my 730i. My buddy also suggested the contact points might be the problems and tried to sand paper the points but warning message still comes on. I'm working on buying new tail lights anyway (the whole unit!) and Im optimistic that the problem will go away.
Sarot is offline   Reply With Quote
ABS light, brake light and TCS offline on 528i... ideas? rmory 5-Series (E12,E28, E34, E39, E60) 5 08-14-2008 10:01 AM
Brake Light Circuit And Tail Light Failure 325is1994 3-Series (E36) 7 08-05-2008 12:00 PM
Brake Light Circut Check Light sre2114 3-Series (E36) 1 10-16-2004 10:36 AM
'94 318is: brake light & fog light question ultraviolet353 3-Series (E36) 2 08-14-2004 01:46 AM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
