Belt Tensioner On 01 X5 3.0 - BMW Forum - BimmerWerkz.com
Old 12-29-2004, 08:08 AM   #1 (permalink)
serrano is an unknown quantity at this point
Greetings to all;
I have an 01 X5 3.0 and it started to develop a grinding noise in the last litle while coming from the inside of the engine bay.
It was diagnosed as a faulty Belt Tensioner;
Here is the list of parts that I suposedlly need, has anyone changed these before, is this a do it yourself job ?? all Help is preciated.
It seems that its the same parts as for the E36
11-28-1-706-545 FAN BELT
11-28-1-726-774 E36 PLATE
11-28-1-726-773 E36 PITMAN ARM
11-28-1-748-131 E36 ADJUSTING PULLE
07-1 1-9-920-1 50 BOLT
11-28-1-717-188 E36 BELT TENSIONER
07-11-9-913-111 HEX BOLT M8X35
07-1 1-9-912-652 HEX BOLT M8X50
07-11-9-901-785 HEX BOLT M8X105
11-28-1-440-369 E36 FLAT WASHER
07-1 1-9-932-121 WAVE WASHER
11-28-1-727-159 E36 PROTECTION CAP
12-31-1-713-143 E36 PROTECTION CAP
11-28-1-730-532 E36 PROTECTION RING
Total for the parts is around 380/460 CAD
do I need all the nuts and bolts ??
Thanks guys
serrano is offline   Reply With Quote
Old 01-09-2005, 07:22 PM   #2 (permalink)
TECH's Avatar
Originally posted by serrano@Dec 29 2004, 08:08 AM
Greetings to all;
Thanks guys
[snapback]260195[/snapback]
That parts list is taken off of a service bulletin that updates the mechanical tensioner (originally on the vehicle), and installs a hydraulic tensioner.
Yes, all those parts are needed, as it's a different mounting setup and tensioner altogether. If you are out of warranty, and want to go cheaper, you can reuse the original belt........IF it's in good shape.
If you insist, you can have the original style installed, but I'm not sure if it's a cheaper part.......the new style is better.......that's why there's a bulletin on it.
Old 01-11-2005, 07:59 PM   #3 (permalink)
Originally posted by TECH+Jan 9 2005, 06:22 PM--><div class='quotetop'>QUOTE(TECH @ Jan 9 2005, 06:22 PM)</div><div class='quotemain'><!--QuoteBegin-serrano@Dec 29 2004, 08:08 AM
Greetings to all;
Here is the list of parts that I suposedlly need, has anyone changed these before, is this a do it yourself job ??* all Help is preciated.
Thanks guys
[snapback]267667[/snapback]
[/b][/quote]
Thanks a lot for the info I will get it and install it.
Belt Tensioner Shudogg 3-Series (E36) 14 01-29-2006 09:34 PM
A.c Belt Tensioner Pulley Bearing cleoh 3-Series (E46, E90) 0 05-24-2005 04:38 PM
Wtb: Ac Belt Tensioner For 318 over the edge Classifieds Sell & Buy 0 11-27-2004 08:04 AM
Passenger Side Seat Belt Install YoungExec728 3-Series (E36) 1 10-13-2004 12:34 AM
small belt tensioner dmonk 3-Series (E36) 2 03-15-2004 02:26 PM
