ASC light with Trans problem (hand-in-hand?) - BMW Forum - BimmerWerkz.com
Old 09-09-2010, 09:20 PM   #1 (permalink)
GasPumper is on a distinguished road
1997 740iL:
Water pump replaced by not-so-BMW shop (as an emergency fix, wife's car, I had no time). Returned from shop with ASC light on and a transmission issue.
Symptoms:
1: ASC light on regardless of engine running or not. Switch has no effect.
2: Transmission "slams" into gear when put into any forward driving gear. Reverse feels "normal." Trans will not shift (at all) into any other gear when in "A"; trans shifts fine when "M" is engaged and shift by hand.
Car has 117k on the clock and in otherwise "fair" shape.
Question to you all is that is there some harness, wiring that could have been disconnected/frayed/damaged near the front of engine that the shop didn't reconnect/notice/fix that be causing the issue? It seems to be a DSC(?) issue?
Thanks in advance,
Gas
GasPumper is offline   Reply With Quote
Old 09-10-2010, 08:56 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz.
Try disconnecting the battery for 20 minutes and then reconnect. It may help reset something that was upset during the repair works? Are there any obviously disconnected connectors around the water pump / expansion bottle area?
Were there any symptoms prior to having the water pump changed?
Riding in style
Hand brake light problem engrsmh 3-Series (E46, E90) 1 11-11-2009 05:59 AM
My new X5 had hand break problem 8 times in 2 years! dwu01 X Series 1 09-01-2009 01:26 AM
hand or machine buff nelzabob Wash & Detail 8 09-28-2007 10:11 PM
could someone give me a hand? saltshaker185 Picture Showroom 10 08-24-2006 08:39 PM
Right or left hand driving? dutchbmw Bimmer Talk/Motorsports Talk 0 07-01-2004 01:17 PM
