ABS and ASC signs - BMW Forum - BimmerWerkz.com
Old 10-09-2003, 01:49 AM   #1 (permalink)
bu3oof is an unknown quantity at this point
Hi Gentelmen
I have noticed that ABS and ASC signs were beaming together at the same time.
This happened for me 4 to 5 times. Some times happen to me while
my driving
Is this a common thing and it will go later or there is a really problem in
the car.
what shall i do.
bu3oof is offline   Reply With Quote
Old 12-09-2003, 06:53 AM   #2 (permalink)
dwarf is an unknown quantity at this point
Hello,
I have the same problem now !!!
Have you got some info ?
BMW changed the sensor but the problem is still here..
dwarf is offline   Reply With Quote
Old 12-09-2003, 07:06 AM   #3 (permalink)
ex owner/admin
Furious's Avatar
when is it happening guys? while driving over corse road or braking? gimme some info
Old 12-10-2003, 05:16 AM   #4 (permalink)
On the road (clean). It seems that if I drive under 60 km/h I will have the problem, If I drive over I will not have the problem ....
Strange ...
Old 12-11-2003, 05:38 AM   #5 (permalink)
EXtech's Avatar
Really, the only thing to do is have the fault memory checked. You may have a control unit taking a dump (it happens alot). If you have any warranty, definitely take it in.
Dwarf, I would take it back and have the dealer check the faults and perform a test plan on the system. They shouldn't charge you since they misdiagnosed it. I am curious how many miles you guys have on your cars???
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 12-18-2003, 03:55 AM   #6 (permalink)
129000 km
I made a new test, if I stay on the parking place, after 20 mn the ASC and ABS led are on.
ghead
