97 740il head gasket problem - BMW Forum - BimmerWerkz.com
Old 01-14-2009, 12:36 AM   #1 (permalink)
jflester is on a distinguished road
Radiator was blowing out coolant after running for about 10 minutes. Had heads milled and replaced gaskets. Still creating superheated steam and blowing out coolant, engine doesn't overheat at all, however does show missfire code for 1,2 and 4. Has new thermostat and good water pump. Wondering if it is possible for the block to warp also or if this can be caused from a water circulation problem. Thanks..
jflester is offline   Reply With Quote
Old 01-14-2009, 11:12 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I wouldnt have thought its anything to do with the block, do you have the stat in the correct way around?, have you over-filled the coolant?, are the plugs new or old ? as for the misfire did you erase all the old codes before starting the car after the rebuild? as they could be old codes.
As for the steam, these engines get very hot very quick, normally if there is to much coolant in there it will get it out on its own.
E39 suspected head gasket problem JMTC 5-Series (E12,E28, E34, E39, E60) 2 07-19-2008 02:21 AM
Head gasket problem? Uh, oh. ozarkmark 5-Series (E12,E28, E34, E39, E60) 5 02-27-2006 11:39 PM
Help Does A Blown Head Gasket/head Make Noise? E36k224 3-Series (E36) 7 03-17-2005 12:18 PM
Loud Engine Noise And Head Gasket Problem dshrewd1 3-Series (E36) 0 11-12-2004 04:25 PM
Blown head gasket, new motor or new gasket? Bmw528i 5-Series (E12,E28, E34, E39, E60) 9 07-07-2004 01:06 AM
