95 E38 Lambda Control #1 Lambda Contro; #2 - BMW Forum - BimmerWerkz.com
Old 02-15-2010, 09:07 PM   #1 (permalink)
Sugarmel is an unknown quantity at this point
Question 95 E38 Lambda Control #1 Lambda Contro; #2
Hi, my check engine light comes on when my car is running rough. I am getting four codes. My Peake scan tool is giving me:
0D : O2 Sensor #1
0C : O2 Sensor #2
C9 : Lambda Control #1
CB : Lambda Control #2
My car runs smooth sometimes, and when it does for a long time, the check engine light goes off. Can the last two codes cause the first two?
Sugarmel is offline   Reply With Quote
Old 02-15-2010, 10:31 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lambda codes are set when the O2 correction goes out-of-range.
In cases, like this, I would train my sights first on checking the MAF, and checking for air leaks(loose clamps, cracked boots or disconnected hose) and checking for leaks also in the intake manifold.
Correct any faults, Clear the codes and RETEST.
With some luck, the readings can be brought within range and u won't need new O2 sensors although BMW does recommend u replace them every 50,000miles.
good luck.
Old 02-16-2010, 02:44 AM   #3 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
The o2 sensors have probably reached full adaption levels, reset the adaptions and see how it goes, I had one o2 sensor that reach the full level about every three months, in the end I did change it, it will affect your mpg.
Old 05-11-2010, 05:42 PM   #4 (permalink)
Car: Bmw e38 L7
Korisx4 is on a distinguished road
E38
I have the same problem ... I check all the boots and there. Good i change my 2. O2 sensors and still get the same thing... You guys think i need to change the catalyc converter????? That will be $$$$
0D : O2 Sensor #1
0C : O2 Sensor #2
Korisx4 is offline   Reply With Quote
328i lambda........ dudehog 3-Series (E36) 15 02-22-2009 11:14 PM
Check Engine Code 1222: Lambda Control #1 ? Delmarco 3-Series (E36) 4 04-16-2008 11:13 PM
Urgent! what is Lambda Control #1 brycealicious 3-Series (E21, E30) 8 04-15-2008 11:05 AM
What the hell is LAMBDA Control #1 jrhaile 3-Series (E36) 8 09-09-2004 05:43 AM
LAMBDA RELAY / 82 320I djeros 3-Series (E21, E30) 1 01-12-2004 08:44 PM
