95 740i Radio sound problems - BMW Forum - BimmerWerkz.com
Old 02-08-2009, 11:16 AM   #1 (permalink)
Car: 1995 740i
tberardi is on a distinguished road
Radio stopped working after going over a bump on the freeway last summer.
Could never resolve the problem since.
I played with all the settings on MID, cassette and DSP to no avail.
You can hear the music from radio or cassette if you put your ear beside the speaker but it is very faint.
CD player works well and sound good without any problems.
I decided to take apart the Philips amp and cassette radio
and resoldered all the cold joints but this did not help at all.
I also checked to see if the phone mute was ON
but it was not although the phone is not in service.
I also happened to punch in Function 5 and now it is Locked
and I don't know the 3 digit code to unlock it.
I realize the amp is a two channel DSP unit (94 Philips unit),
however, If the CD player works than 1 channel should be good
and possibly the other channel which handles the radio & cassette has failed.
Anyone can lead me on how to test this;
or any help or direction on how to resolve the faint radio sound problem.
Also looking for help on how to unlock the phone without knowing the PIN number (it bothers me that it is locked even though I don't use ithe phone).
Thanks in advance.
tberardi is offline   Reply With Quote
Old 02-09-2009, 06:32 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
The phone maybe at default code: 1 2 3 4 then OK. If this doesnt work disconnect the batt for 10 minutes it may reset it to default then try again.
Old 02-16-2009, 11:15 PM   #3 (permalink)
Car: 1995 740i
Default numbers & no power suggested by Marti5 did not work unfortunately.
Seeing no other suggested solutions, I will revert to punching in all possible 3 digit codes.
There are only 999 combinations.
If I do 100 a day, I will find it in 10 days or less.
200 so far, 800 to go.
Old 02-18-2009, 07:51 PM   #4 (permalink)
caleb27 is on a distinguished road
Most likely your Phillips DSP amp has failed. Phillips DSP's have a tendency to do that. Try to find a Loewe or Lear DSP amp online or Ebay and you should be good. I had the same problem and that solved it.
caleb27 is offline   Reply With Quote
1995 740i problems.....any one had same dotcomdan 1,6,7,8 - Series and Mini Cooper 1 10-30-2008 07:52 PM
1995 740i problems......please help dotcomdan 1,6,7,8 - Series and Mini Cooper 2 10-30-2008 10:47 AM
1995 740i Problems meh001 1,6,7,8 - Series and Mini Cooper 2 02-08-2005 02:51 PM
1993 740i Radio???? robob69 1,6,7,8 - Series and Mini Cooper 1 09-23-2004 10:43 PM
1995 740i Radio / Audio System wmccally 1,6,7,8 - Series and Mini Cooper 1 04-19-2004 12:11 AM
