95 740i Fog Light problem - BMW Forum - BimmerWerkz.com
Old 02-16-2009, 12:11 AM   #1 (permalink)
Car: 1995 740i
tberardi is on a distinguished road
My right fog light always stays on even when I turn the car off.
I had to disconnect the plug to prevent it from draining the battery.
The left one works as it should with the interior switch.
Can someone help me diagnose this.
Also, when I removed the left foglight, I found a wired plug with a 2" long 1/8" thick needle on it laying down on the bottom loose.
Is the thermocouple for the outdoor temperature guage and is it supposed to lay down loose.
tberardi is offline   Reply With Quote
Old 02-16-2009, 04:01 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
The needle thingy is indeed the outside temp sensor, there should be a clip for this, unless its broken off, as for the light, trace the wires as far back as possible there must be a short somewhere, also clean up the bulb holder, you could try a new ground off the bulb holder to see if its the ground thats the problem.
Old 02-16-2009, 11:10 PM   #3 (permalink)
Car: 1995 740i
Thanks Marti5.
After studying the circuit with my electrical engineer brother in law-- we figure it could also be a fused relay. Will test the circuits next weekend.
If its the relay, I will take it apart and fix it.
Kind of used to doing this sort of thing on my Volvo 740T.
Fog light problem E-34 kvt2x6 5-Series (E12,E28, E34, E39, E60) 2 04-18-2008 04:26 PM
Fog light problem HELP! Tochenzo 3-Series (E36) 3 10-10-2006 12:43 AM
Fog Light problem bimmerguy82 3-Series (E36) 4 08-16-2006 05:35 PM
'94 318is: brake light & fog light question ultraviolet353 3-Series (E36) 2 08-14-2004 01:46 AM
fog light wiring problem Scarface 3-Series (E36) 2 05-16-2003 08:52 PM
