93 740il "TRANS PROGRAM" - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 07-03-2004, 05:20 PM Thread Starter
93 740iL is an unknown quantity at this point
I was driving under normal conditions when the transmission acted up and the "TRANS PROGRAM" displayed on the dash. I pulled the car over, let it rest for about 30 minutes, and then started it up with no problems. The tranny then acted fine. I've driven it 2 days since this occured and have had no problems. What would cause this? Is my transmission on the way out. I just bought the car from an Auto Broker so I'm trying to figure out what I need to do if this is a major problem. Thanks.
93 740iL is offline
post #2 of 4 (permalink) Old 09-09-2004, 12:09 PM
As a BMW tech of many I can say that the ZF autobox fitted to your car is very relieable, Themost common cause of thius fault on this model is the serlector switch which is mounted on the gear lever. Get the fault memory for the EGS (gearbox ecu) check and this fault should be stored.
bad man working is offline
post #3 of 4 (permalink) Old 09-13-2004, 06:29 PM
I agree, the neutral safety/backup light/gear selector switch is responsible for many problems. You can access the switch by first taking the S/E/M or A/M selector on the left of the shifter out ( it prys out and then the connector disconnects) and then releasing the shifter handle (be careful to hold the shifter trigger up or depressed, I use duct tape or the plastic rod will fall out and ypu will have to reatatch (no big deal unless this is afirst time)to the pin behind the trigger. The consloe wood then can be pried out starting at front corner and then you will see the white platic shfter assembly in the shifter cavity and next to shift rod. Easier to go to www.nmia.com/~dgnrg/page_2.htm which is Don Gales How to, with picture and text.
Bear is offline
post #4 of 4 (permalink) Old 10-26-2004, 04:53 PM
7series Land Yacht is an unknown quantity at this point
I had this problem with my '98 740iL. Turns out that my Tranny was not on the way out, but instead, there was a problem with the throttle regulator. I'd recomend having this checked out, as the problem hasn't occured since I had this part fixed.
7series Land Yacht is offline
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 1,6,7,8 - Series and Mini Cooper
Please Help If You Have Carfax Time Left. ozbmw 1,6,7,8 - Series and Mini Cooper 4 08-07-2007 08:48 PM
1995 740il Power Steering Problem leejgray 1,6,7,8 - Series and Mini Cooper 0 02-27-2005 03:00 PM
740iL Sport transmission differences please Bread 1,6,7,8 - Series and Mini Cooper 1 08-29-2004 01:35 AM
1998 740iL a decent deal? playdrv4me 1,6,7,8 - Series and Mini Cooper 2 01-21-2004 08:15 AM
1995 740il engine replacement/recall Destin 1,6,7,8 - Series and Mini Cooper 3 09-25-2003 12:35 PM
