93 740il no reverse - BMW Forum - BimmerWerkz.com
post #1 of 18 (permalink) Old 01-05-2008, 03:09 PM Thread Starter
740bryon is on a distinguished road
93 740il no reverse
When cold weather hit. the trans started to either hard shift or delayed shift from park to reverse or neutral to reverse. then after a week of this, it would not go into reverse at all. Forward works fine thru all gears. I tried 1 test drive to see if it would work once warmed up. no change. I haven't tried anything else since. I have been searching sites for 740s with similar problems, and I have heard that it might be a plastic check valve inside the tranny. Does anyone know which valve it is? where to get the part? and is this something that can be replaced with out major Z5 540 transmission knowledge
I haven't put it on the rack yet so checking fluid level, shifter linkage. fluid and filter service and the checking the A/M switch have not been ruled out yet.
I'm in rural Montana with limited BMW mechanic access. so I am learning everthing I can before I start to do this repair myself.
740bryon is offline
post #2 of 18 (permalink) Old 01-05-2008, 03:18 PM
chinonca's Avatar
chinonca is on a distinguished road
^^Do you have any codes??
chinonca is offline
post #3 of 18 (permalink) Old 01-05-2008, 03:29 PM Thread Starter
not yet. the nearest person with a code reader is about 180 miles away
740bryon is offline
post #4 of 18 (permalink) Old 01-05-2008, 07:09 PM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
^ is it throwing codes?
a/m switch? never heard of being linked to reverse issues....
how many miles?
last fluid and filter change.......
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #5 of 18 (permalink) Old 01-05-2008, 10:56 PM Thread Starter
there is nothing on the dash indicating trouble. the car has 137,000 miles. It runs great no problems until reverse stopped working.
740bryon is offline
post #6 of 18 (permalink) Old 01-05-2008, 11:11 PM
Try e38.org BMW 7-series information and links
post #7 of 18 (permalink) Old 01-06-2008, 03:18 PM Thread Starter
alpine
thanks for the link I will keep going to 740 school.
740bryon is offline
post #8 of 18 (permalink) Old 01-06-2008, 06:11 PM
yeah I love my 740il too there great cars you will surly love the car when it is fixed if you dont already love it............
post #9 of 18 (permalink) Old 01-07-2008, 01:04 AM Thread Starter
alpine
went to the e32.org site and found most of what I was looking for. A pictorial instruction on the 5hp filter and valve body replacement WOW what a machine. can't wait to put it back on the road.
740bryon is offline
post #10 of 18 (permalink) Old 01-07-2008, 01:07 AM
yep they rock you have an e32 lol sry i didnt see 93 they have alotta info on the 7 series cars
post #11 of 18 (permalink) Old 01-07-2008, 01:14 AM
chinonca's Avatar
So wat was the problem with the tranny?? Filter??
chinonca is offline
post #12 of 18 (permalink) Old 01-07-2008, 02:13 AM
valve body?
post #13 of 18 (permalink) Old 01-07-2008, 02:33 AM
dvmotorsports is on a distinguished road
valve body?
BINGO!
BMW Technician
dvmotorsports is offline
post #14 of 18 (permalink) Old 01-07-2008, 06:23 AM
^ lol yay i guessed right hopefully...... Bryon any update do you plan to DIY?
post #15 of 18 (permalink) Old 01-07-2008, 11:34 AM Thread Starter
thanks for your help
I am still going to school for this project.
The most likely suspected problems I have learned so far, with out having a code reader are
dirty electric shift control from lack of cup holders
mis-adjusted manual shift linkage
sticking valve body
low fluid
clogged filter
worn plastic check valve
I still plan to DIY the project. I am planning to rebuild the valve body assembly since it is known that the ball check valves wear out. I haven't been able to put it on the rack yet. Winter up here in Montana has a way of slowing you down. still have to order parts, nothing local is available.
I am still looking for more sources of info. I want to make sure I do this project only once
740bryon is offline
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 1,6,7,8 - Series and Mini Cooper
No Reverse bad man working 1,6,7,8 - Series and Mini Cooper 5 09-11-2005 12:53 PM
94 740IL won't go into reverse dickcsf 1,6,7,8 - Series and Mini Cooper 3 09-28-2004 03:51 PM
Clutch not angaging on reverse gear! 4tunesfool 3-Series (E46, E90) 7 09-17-2004 09:41 AM
No clutch engagement in Reverse? 4tunesfool 3-Series (E36) 3 09-05-2004 07:37 AM
Manual Trans Stuck in Reverse motorwaybmw 3-Series (E21, E30) 10 03-25-2004 11:14 AM
