92 735il rough running on Idle - BMW Forum - BimmerWerkz.com
Old 02-05-2009, 06:54 AM   #1 (permalink)
csf1975 is on a distinguished road
The car really runs rough when it is sitting and idling. but when reved up it smooths out
I have changed and cleaned almost everything. "all sensor's and plugs and wires" the car has the 3.5 straight 6 I'm lost
csf1975 is offline   Reply With Quote
Old 02-05-2009, 09:42 AM   #2 (permalink)
I'd have a look at the intake boot for cracks; this was the issue for my E30.
Old 02-05-2009, 10:27 AM   #3 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Could be the MAF.
Old 02-06-2009, 05:46 AM   #4 (permalink)
It does seem like there is a massive vacum leak around the intake manifold. I will know more today when I tear into it.. but I did pull codes and the O2 sensor is saying it's bad
Old 02-06-2009, 06:23 AM   #5 (permalink)
marti5's Avatar
Go with the air leak 1st, the o2 is probably picking up incorrect mixture values due to vaccum leak.
Old 02-06-2009, 06:52 PM   #6 (permalink)
Car: 325i, 750iL
drivinfaster is on a distinguished road
do you have a vacuum guage?? if not, get one. it's fairly self explanitary. needle in the green is good. if it is bouncy, then there is a dead cylinder. WHY the cylinder is dead could be a few things, but one that comes to mind is a intake manifold gasket. a propane tank (like for camping lanterns) and a torch fitting with a rubber hose can be used (unlit) to 'sniff' along the intake where the 'miss' is. if the idle changes, you have found a leak. a can of carb cleaner could also do the trick, but can be tough to control in tight quarters.
df
drivinfaster is offline   Reply With Quote
Rough idle & jumping idle ///M Power 3-Series (E36) 4 12-22-2008 05:20 PM
rough running 99 ///M3 M-Series (M1, M3, M5, M6) 2 09-30-2008 08:49 PM
Running rough bagelboy91 3-Series (E21, E30) 11 12-10-2007 01:03 AM
E36 Rough Idle - May Be Running Rich Then Lean... Seros 3-Series (E36) 2 02-21-2005 05:27 PM
Rough running AndyBaloch 3-Series (E36) 5 08-11-2004 03:00 AM
