840ci fuse box - BMW Forum - BimmerWerkz.com
Old 05-21-2007, 05:03 PM   #1 (permalink)
steve1 is on a distinguished road
840ci fuse box
I was wondering if anyone knew where to get a fuse box diagram identifying the fuses ans relays on a 95 840ci. I checked the dealers and they cant get one. Thanks
steve1 is offline   Reply With Quote
Old 05-22-2007, 10:45 AM   #2 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
The diagram label is inside the fusebox. Look inside the fuse box cover.
LOS
Old 05-22-2007, 02:50 PM   #3 (permalink)
thanks for the reply, unfortunately it isnt on mine. Do you know who would have a diagram for it, also the one located in the trunk?
Old 05-22-2007, 03:03 PM   #4 (permalink)
LOS
LOS's Avatar
You won't find a diagram anywhere. It's strange, the label is attached to the box. Anyway, no worries. I'll drive the car tomorrow and a take a couple of pics!
LOS
Old 05-22-2007, 05:25 PM   #5 (permalink)
thanks, what about the one in the trunk
Old 05-23-2007, 12:44 PM   #6 (permalink)
LOS
LOS's Avatar
Steve1, I hope this works. I took a picture of the cover. I didn't see a diagram for the rear circuit breaker/fuses.
The PDF file was too large. so here is a pic instead.
LOS
Old 05-23-2007, 12:48 PM   #7 (permalink)
LOS
LOS's Avatar
Upper right corner box, there are 4 fuses (you can barely read it on the pic). Anyway, the numbers are
48
51
60
63
For small rectangular box:
29 1
52
55
LOS
Old 05-23-2007, 01:25 PM   #8 (permalink)
thank you for that, have you ever had a problem with your headlights, mine seem to only go up or down during the day when the car has not been driven too much.
Old 05-23-2007, 01:48 PM   #9 (permalink)
LOS
LOS's Avatar
I'm glad to help.
No problems so far. That's strange... Check both of your batteries (and fuses, ha ha)... The headlight motors are supposed to last very long! In any case, read your owners manual in case you have to raise your headlights manually. Also, where are you located? Is that the only problem for the headlights? If they're too loose inside the bucket or ifthe adjustment screw is broken, BMW might be able to replace them for free. I have a letter you can take to the dealer just in case. Send me your email privately if you want. The implied warranty is good for 15 yrs I believe.
if you just bought this car, check out this sites...
www.e31.net (this is a great site for model history). Click on links for additional sites.
LOS
Where is fuse 76? Is this the problem anyway? Brassraptor 5-Series (E12,E28, E34, E39, E60) 1 04-24-2010 06:13 PM
Fuse box index/list PhilH 3-Series (E46, E90) 0 02-14-2007 04:48 AM
Battery Drain from fuse #9 midi 5-Series (E12,E28, E34, E39, E60) 2 09-28-2006 02:58 PM
fuse box cymorg 3-Series (E36) 5 02-22-2006 07:52 AM
Fuse Blade Terminal Clips szidikj 3-Series (E21, E30) 0 08-16-2004 10:59 AM
