740il trans problem - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 11-02-2013, 06:08 PM Thread Starter
benenuf is on a distinguished road
740il trans problem
hello forum family here is my problem got into my 98 740il pulled off drove for 1 block at a stop sign started to pull off and car wouldn't move put car in reverse and it would move put back in drive and it would move barely check eng light came on I pulled codes po720 would this code caused this problem. has anyone encountered this problem before please help me forum
benenuf is offline
post #2 of 4 (permalink) Old 11-08-2013, 12:22 PM
AutobahnBMWParts is on a distinguished road
this means your transmission has gone into fail-safe mode. the code will either read "output speed sensor circuit" or "pulse generator".
Basically, the output speed of your transmission wasnt matching what the computer said it should be, therefore it goes into fail safe mode to prevent damage of your transmission.
This could be due to clutch slippage, bad torque converter, a bad sensor, or a few other things. Regardless it wont be a fun fix.
Have you taken it anywhere to get it checked out yet?
AutobahnBMWParts is offline
post #3 of 4 (permalink) Old 11-08-2013, 01:38 PM Thread Starter
No was wondering what I need to do to start my troubleshooting am I going to need to remove the trans ,what should be my first step in troubleshooting.
benenuf is offline
post #4 of 4 (permalink) Old 11-18-2013, 11:08 AM
c_zellars is on a distinguished road
I would drain the Transmission Fluid and drop the Transmission Pan to have a look for any signs of damage. Be prepared to change the filter, fluid and gasket. Keep in mind that the trans pan bolts are torx type that should be replaced.
c_zellars is offline
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 1,6,7,8 - Series and Mini Cooper
94 740il trans fail code oted 1,6,7,8 - Series and Mini Cooper 7 09-30-2008 07:38 PM
Help with 94 740il Trans. Progam message kjair81 1,6,7,8 - Series and Mini Cooper 0 02-20-2007 05:07 PM
Trans. Problem bavariankid06 3-Series (E21, E30) 2 11-03-2004 11:21 AM
93 740il "TRANS PROGRAM" 93 740iL 1,6,7,8 - Series and Mini Cooper 3 10-26-2004 05:53 PM
740il Auto Trans Fluid tknesek 1,6,7,8 - Series and Mini Cooper 3 02-04-2004 09:12 AM
