740IL Cam Sensor doubt diagnosis - BMW Forum - BimmerWerkz.com
Old 01-17-2009, 09:44 PM   #1 (permalink)
740Gal is on a distinguished road
Wink 740IL Cam Sensor doubt diagnosis
Hi All.
I'm new but have been reading alot on E38 and areas. My mechanic states I need a new Cam Sensor according to my SES readout. (of which I don't know what the code is). My understanding is that if the Cam Sensor was bad, the car would be stalling or not starting. The only thing I noticed it's doing is, sometimes a "jump" when I slow down and take a turn while applying the gas coming out of it. Usually turning to the left. I don't want to pay for a part I don't need. But if I do, can probably DIY.
Any ideas? 99' 740IL 139,000
740Gal is offline   Reply With Quote
Old 01-18-2009, 05:43 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Deffo DIY, Camshaft sensor mainly controls the injectors, as why it does it when you turn left should not make a difference to the cam sensor, when was the last time you changed the fuel filter?? as it sounds more like a fuel problem to me.
You also mention a 'jump' do you mean transmission jump as no forward drive for a second then kicks in?? if so when was the last time you had a transmission service?? should be done 80-90K then every 30-40K.
Old 01-18-2009, 08:08 AM   #3 (permalink)
Hi Marty,
They are getting ready to service the trans this week, as the seal needs replacing. So maybe that will cure the "jump". And yes, that's what I mean. As I come out of the turn it jumps.
As for the fuel filter, they just did an oil change, but did not list all they replaced. I doubt they changed it.
I assume I'm right on the Cam Sensor? If it was bad it would be stalling or not starting? Thanks.
Old 01-18-2009, 08:24 AM   #4 (permalink)
marti5's Avatar
Well, It should go better after a transmission service ( no jump) make sure they change the trans filter and not just give it a clean, as for the cam sensor, yes you are up the right street so to speak, you also have a crankshaft sensor, which will make it not start.
What I would do, is get them to erase the error,and re do a diagnostics again say in around 2 weeks if the same thing comes back then its on its way out, if all is clear dont worry, sometimes these cars pop up errors at Lib.
I dont think you have anything to worry about at this stage, but I would advise a fuel filter change anyway.
If you get any further problems just PM me.
Cam sensor installation kol2upt3d 1,6,7,8 - Series and Mini Cooper 4 09-04-2007 12:07 PM
Which Cam Sensor? tsydej1 3-Series (E46, E90) 3 07-09-2007 08:52 PM
Cam sensor on E39 M5 Trevize M-Series (M1, M3, M5, M6) 1 03-06-2007 09:51 AM
Hesitiation.mass Airflow Sensor Or Cam Pos Sensor? scopefrfd 5-Series (E12,E28, E34, E39, E60) 7 04-24-2005 11:47 AM
cam sensor problem fushuman 3-Series (E36) 12 09-22-2004 02:13 PM
