740il Aux Fan not running on High - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 06-15-2013, 05:55 AM Thread Starter
Slapjack740 is on a distinguished road
Cool 740il Aux Fan not running on High
Tried everything replaced electric fan, thermostat, fan sensor in radiator, fuses are good. low fan operates when a/c comes on, but not in the high speed mode.
As temp. rises a/c clutch kicks on and off, no high speed. Even with a/c off when temp. get high, fan should kick in and cool, but it does not.
What other problem could cause fan not to operate on high.
Slapjack740 is offline
post #2 of 3 (permalink) Old 06-15-2013, 07:22 PM
42, The meaning of life
brettski's Avatar
brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice
Does the auxiliary fan stay running on low speed when it should change over to high speed, or does it turn off totally?
Looking at another post it looks like there may be two resistor packs positioned behind the fan which limit the current flow (and speed) of the fan.
Replaced aux fan resistors on my 97 E39. Same repair kit for E38.
I am not sure if one of the resistor packs is used on the high speed mode, but it may be worth checking the resistor packs (and fan wiring) by disconnecting it (the fan) from the control circuit (connector behind front grill to the right side of the fan), and putting 12v directly onto each (in turn) of the pins (male). You will need a 12VDC supply and negative wire to do this, but if you're not sure about what's required you probably shouldn't be attempting this yourself.
Good luck and let us know how you go.
Riding in style
brettski is offline
post #3 of 3 (permalink) Old 06-16-2013, 07:31 AM Thread Starter
I have replace the fan with a new fan that has the new resistors attach, I can unplug the sensor that goes in to radiator that control the high and low speeds and ground the high speed to the brown wire in the pin and it works. The same with the low speed it works.
All fuses and relay are OK.
The fan will continue to run on low speed as long as the a/c is on, but will not go to high.
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 1,6,7,8 - Series and Mini Cooper
aux fan keeps running??? saleem 3-Series (E46, E90) 15 04-24-2010 07:34 PM
aux. fan switch..... 325guy 3-Series (E21, E30) 2 03-14-2009 12:39 AM
aux fan miami325e 3-Series (E36) 7 06-14-2006 12:20 PM
Aux Fan Not Turning On mrclean 1,6,7,8 - Series and Mini Cooper 12 12-29-2005 09:27 AM
Is the E36 Aux fan the same as the M44 engine fan? Autotechnica 3-Series (E36) 1 04-22-2004 03:37 PM
