730ia ac problem - BMW Forum - BimmerWerkz.com
Old 03-27-2008, 12:41 AM   #1 (permalink)
pakkenswe is on a distinguished road
730ia ac problem
Hi, Im new to the forum and you guys seem to be great at this
I've been around asking many people about my problem and nobody can solve it, hope someone here knows
I have a 730ia -88 and the heater works, but I cant turn on more then 25% blow power, and it's only cold air in the rear?
Thanks
pakkenswe is offline   Reply With Quote
Old 03-30-2008, 07:45 AM   #2 (permalink)
crewdog_843's Avatar
Car: 2001 740i Titanium Silver
crewdog_843 is an unknown quantity at this point
First thing I would check is my cabin filters. Don't know where, or even if your car has them, but most, if not all BMW's with air conditioning have 'em.
These filters, if not cleaned, over time will build up so much dust and grime that no air will pass through. No need to replace the element (when you find them)....just wash, dry, and reinsert.
jake
crewdog_843 is offline   Reply With Quote
Old 03-30-2008, 02:22 PM   #3 (permalink)
thanks for the awnser, shall se if i could find them
Old 03-31-2008, 12:11 PM   #4 (permalink)
This may not cure the problem but will certainly improve airflow and circulation in your car.
Some have reported that their filters were stiff with coagulated mold/pollen/dust, thus no air was passing through, or a moldy smell in the cabin itself.
Where are you located with an '88 730i?
jake
Old 03-31-2008, 01:23 PM   #5 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
What do you mean bu you cant get more the 25% like if you turn the blower up it doesn't speed up any more? or only 25% of the air on max is getting to you?
1992 318i Coupe parts car
I am Captain Obvious
Old 04-04-2008, 07:42 AM   #6 (permalink)
I can turn the regulator all the way but after the point of about 25% the airflow doesnt improve
Old 04-04-2008, 12:30 PM   #7 (permalink)
does the motor sipn faster? if so remove the cabin filters and check then if dirty clean or replace then try again.... BTW where do you drive your car is it dusty at times? annd another Q is do you smoke in the car? because that can clogg them pretty quickly...
Old 04-04-2008, 11:44 PM   #8 (permalink)
I usually just drive in the city..
The guy that i bought it from used to smoke in it, but i dont
You can hear that its trying to spin faster, but its a very quiet sound for only a sec, is something broken or do you think its just clogged.
I removed the panel between the seats and the plastictube wich provide the air to the rear was clogged with leaves, i have a theori that its full at front as well, I would check, if I know how to?
But the clogged thingy doesnt awnser why i cant get any heat in the rear of the car?
Old 04-05-2008, 12:02 AM   #9 (permalink)
...the leaves were IN the tube going to the back? could be there cloggin the heat from getting back there... o and i just saw your car is an 88.... making it an e32 it DOES have cabin filters....
how to check/change them....
http://www.e38.org/e32/microfilter%20change.pdf
heres what i call "the bible" to these cars...
BMW E32 7-series information and links
Old 04-12-2008, 02:45 AM   #10 (permalink)
Yeah they were but ofcourse i remowed them xD
My thought is that they are clogging were the heat come from in the front, thanks for the links, shall check em out!
a problem chrismcl05 3-Series (E36) 5 04-06-2006 04:19 PM
got a problem kyle2blue 3-Series (E36) 9 01-30-2006 08:01 PM
Heater Problem And Oil Problem floydzeppelinfan 3-Series (E36) 1 04-07-2005 10:19 PM
AC problem basmati 3-Series (E46, E90) 0 08-22-2004 07:22 PM
