2000 740il rear brakes... - BMW Forum - BimmerWerkz.com
Old 11-24-2003, 01:25 PM   #1 (permalink)
ags0082 is an unknown quantity at this point
Hello,
I was wondering, i'm about to replace the rear brake pads on a 2000 740il and i've found a tutorial online...but it doesn't mention anything regarding resetting the computer. Does anyone know if there is such a step where I would need to reset the computer or will the sensors detect when I put the new pads in?
Thanks for any help.
-AGS
ags0082 is offline   Reply With Quote
Old 11-25-2003, 09:14 AM   #2 (permalink)
lwebb12's Avatar
Car: 2000 M5
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
i pmed Extech. he may be able to help
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 11-25-2003, 12:20 PM   #3 (permalink)
EXtech's Avatar
it's simple. after replacing the brakes and sensors, turn the key all the way to accessory. Leave it on until the brake sensor light goes off.... then you're done. If for some reason it does not work, try one more time, double check the connections and then go drive it around the block.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 11-25-2003, 12:26 PM   #4 (permalink)
lwebb12's Avatar
Car: 2000 M5
thanks extech
About To Buy 2000 740il, Should I Go For It? got_hp? 1,6,7,8 - Series and Mini Cooper 2 01-27-2006 09:33 AM
330xi Highway Miles, How Long Rear Brakes Last clydesdale 3-Series (E46, E90) 3 02-27-2005 03:39 AM
2000 Bmw 740il carnraj 1,6,7,8 - Series and Mini Cooper 1 02-15-2005 04:50 PM
Rear brakes and rotor help PaulD 5-Series (E12,E28, E34, E39, E60) 1 09-11-2003 08:11 PM
