2000 740i Issues - BMW Forum - BimmerWerkz.com
Old 02-09-2004, 09:17 AM   #1 (permalink)
vevro is an unknown quantity at this point
This is a great forum, I'm glad if found it as I need some expert advice. I've recently sold my 99 Lexus LS400 and I'm currently in the market for a 2000 BMW 740i sport with roughly 50-70k miles. Can someone tell me the major issues I should look out for and typical maintenances that should be done in this mile range. I need to know when the timing belt, water pump and the serpentine belt are due and if there are major issues with the suspension. Also if there are any electrical problems that I should be aware of. Thanks.
vevro is offline   Reply With Quote
Old 04-21-2004, 01:07 PM   #2 (permalink)
shifty's Avatar
shifty is an unknown quantity at this point
Send a message via AIM to shifty
The M62 doesnt have a timing belt, they use chains. They dont need to be changed until way over 200k miles in most cases. The car will require basic maintenance and should cost no more than 1k a year to maintain. Altho, since you're buying the car used there are several things you should check before you purchase the car, such as the power steering lines, look for red fluid on the ground, ATF, models without self leveling use ATF for power steering fluid and a lot of them leak. Check the cooling system, including all coolant lines and radiator and neck. Check if the radiator was replaced, if it wasnt, it'll likely have to be replaced soon, you can check for a stamp on the left side back of it where it's stamped with a part number and date. Drive the car and make sure the transmission is smooth and doesnt whine. As far as electronics go, the only common problem is the loss of pixels in the cluster MID, which can be fixed fairly easily but removing the cluster and cleaning the contact points and connectors inside.
<img src='http://shifta.servebeer.com:8080/sig.gif' border='0' alt='user posted image' />
shifty is offline   Reply With Quote
How To Tell Options With Vin? cm70man 5-Series (E12,E28, E34, E39, E60) 18 12-31-2010 01:05 AM
Bmwtechs Just Bought A 2000 740il, Has Some Issues playdrv4me 1,6,7,8 - Series and Mini Cooper 2 11-25-2004 12:27 AM
2000 740i Sport Rims M7 boostedga Classifieds Sell & Buy 0 10-28-2004 09:32 PM
2000 or 2002 M5 Question vvanherk M-Series (M1, M3, M5, M6) 5 09-03-2004 08:56 AM
