1995 740il front end shimmy - BMW Forum - BimmerWerkz.com
Old 02-29-2004, 06:26 AM   #1 (permalink)
mike727 is an unknown quantity at this point
I have a 740 il with m parrallel wheels , and the problem is at about 43mph the front end begins to shake like the wheels are falling off.Once i go alittle faster it goes away. I had the tires balenced 3 times using the road force machine and I also changed the tires and wheels and it still has not changed .
Has anyone had this problem? And where do I look next. used
mike727 is offline   Reply With Quote
Old 02-29-2004, 02:01 PM   #2 (permalink)
e36_m3_Turbo's Avatar
are they rubbing on the ball joints or tie rods? that happened to me few weeks ago. if it feels sorta shaky and sorta flat feeler, check it before it kills your tires
No longer red.
Old 03-01-2004, 06:54 PM   #3 (permalink)
EXtech's Avatar
sounds to me like the entire front suspension needs a carefull look over. Idler arm, centerlink, sway bar end links, ball joints and even the thrust arm bushings. Any of these things worn out can cause the symptoms that you are having. How many miles are on the car??
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 03-03-2004, 06:44 AM   #4 (permalink)
95000 miles.
Old 03-03-2004, 07:55 AM   #5 (permalink)
Kjay is an unknown quantity at this point
Try looking at the control arm bushing too. My front was shaking and thats what the problem was, so maby it will help you out.
Kjay is offline   Reply With Quote
Old 03-04-2004, 07:30 PM   #6 (permalink)
EXtech's Avatar
yeah Mike, sounds like it is time to have everything checked. Be prepared to spend some $$ though. With 95k on a 740 I am willing to bet alot of replacing is in order (unless the previous owner has recently done so). And as I mentioned in my last post and as Kjay has managed to repeat, check the control arm bushings (thrust bushings).
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 03-05-2004, 05:38 AM   #7 (permalink)
Thanks for the info i know ther was some front end work done by the last owner I checked the dealer that he went to , He actualy kept all the service records.
Old 03-08-2004, 11:10 PM   #8 (permalink)
TECH's Avatar
I vote for the "push strut" bushings as mentioned above. They'll cause that very shimmy at about 40 mph, and it'll go away as you speed up.
It could be other issues as well, it needs to be looked over.
1995 740il Power Steering Problem leejgray 1,6,7,8 - Series and Mini Cooper 0 02-27-2005 03:00 PM
'94 740iL Front Fender Part Dragging Billy Ray 1,6,7,8 - Series and Mini Cooper 1 09-12-2004 08:50 PM
A Ghost in my front end... Name: Shimmy Spector mathetas 3-Series (E36) 3 08-27-2004 10:47 PM
Ghost Haunting Front End: Shimmy Spector mathetas 3-Series (E36) 1 08-26-2004 08:40 PM
1995 740il engine replacement/recall Destin 1,6,7,8 - Series and Mini Cooper 3 09-25-2003 12:35 PM
