1995 740il engine replacement/recall - BMW Forum - BimmerWerkz.com
Old 08-03-2003, 09:34 AM   #1 (permalink)
Destin is an unknown quantity at this point
Hi.
Does anyone know if the 1995 740il model was subject to the engine replacement recall?
I am looking to buy a 1995 740il, and just curious what advice or insite you guys can share with me - both good and bad....
Thanks.
Destin is offline   Reply With Quote
Old 08-03-2003, 12:23 PM   #2 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
Only recall that I have come across is this..
Bayerische Motoren Werke
Models: BMW 740i Years: 1995-1997
BMW 740iL Years: 1995-1997
BMW 750iL Years: 1995-1997
Number Involved: 29,000 Dates of Manufacture: September 1994 - August 1996 NHTSA Recall No.: 97V140 Vehicle Description: Passenger vehicles. Description of Defect: Road grit and gravel associated with winter road conditions can penetrate the rubber of the lower front spring mounts and accumulate in the mounts, causing notches or pits to develop. These notches can develop cracks, resulting in breakage of a bottom coil of the spring. Consequence of Defect: The vehicle's ride height could be affected, causing noise while the vehicle is driven. The vehicle's dynamic stability can be affected, reducing the driver's ability to maintain control of the vehicle. Corrective Action: Dealers will replace both front springs and lower spring mounts. Owner Notification: Owner notification is expected to begin by the end of October 1997. Note: Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact BMW at 1-800-831-1117.
Advice on the ride?? How many miles, asking price, condition,..etc.
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 08-05-2003, 11:56 PM   #3 (permalink)
EXtech's Avatar
You have to get the engine code off the engine block. The dealer will pull a dcs to see if it has ever been done. They will check the block to verify.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 09-25-2003, 12:35 PM   #4 (permalink)
Gympie is an unknown quantity at this point
During this year of production there was a Nickel Coating placed on the liners called Nikasil. Not sure if the subject vehicle has it or not. This link will offer more information: http://www.lestac.co.uk/bmw/nikasil.htm#what_is
BMW was for a short time replacing the engines, but has turned into He-said, She-said issue.
Gympie
Gympie is offline   Reply With Quote
1995 M3 new engine search.. 1995-BMW-M3 M-Series (M1, M3, M5, M6) 4 10-14-2005 07:42 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
1995 740il Power Steering Problem leejgray 1,6,7,8 - Series and Mini Cooper 0 02-27-2005 03:00 PM
