1994 740i Door Locks - BMW Forum - BimmerWerkz.com
Old 07-02-2003, 02:33 PM   #1 (permalink)
agsiegel is an unknown quantity at this point
My power door locks work fine from the remote and when you use the key in the doors. However when you are in the car and manually push down the driver's door lock/plunger, all locks are supposed to close. Only the driver's lock closes. All other locks must be closed manually. Any ideas? Thanks!
agsiegel is offline   Reply With Quote
Old 07-02-2003, 05:14 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
Hi first welcome to the Forums. its good to see more 7 series owners aboard, now sounds to me like a relay might be malfuntioning. is there any mechanical or electrical noises when you engage the drivers lock? also maybe check behind the door skin. your looking for serious corrosion. failing all that take it to the mechanic. it doesnt sound like an expensive fix, but just in case get an estimate first.
Old 07-19-2003, 12:06 AM   #3 (permalink)
hang 10 is an unknown quantity at this point
Send a message via AIM to hang 10
welcome hope you can stay
<a href="http://www.iaapparel.com" target="_blank"><img src="http://www.european-forums.com/forums/uploads/post-1-1125957927.jpg"></a>
hang 10 is offline   Reply With Quote
Old 08-06-2003, 08:44 PM   #4 (permalink)
EXtech's Avatar
if you use the key in the driver's door, does it lock all others?
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
0-60 1/4mile Rooz Bimmer Talk/Motorsports Talk 8 01-21-2005 08:41 PM
Vin Number skimmilk 5-Series (E12,E28, E34, E39, E60) 1 12-16-2004 05:07 PM
325i Performance Stats Darkmage 3-Series (E36) 8 08-26-2004 07:03 PM
BMW Racers out there... jrhaile 3-Series (E36) 13 05-17-2004 05:47 PM
1994 and 1995 750iL's...recommendations? playdrv4me 1,6,7,8 - Series and Mini Cooper 1 02-08-2004 11:45 PM
