01 E38 Abs Locking Up????helllppp!!!!! - BMW Forum - BimmerWerkz.com
Old 02-26-2010, 07:26 AM   #1 (permalink)
BimmerE38Man is on a distinguished road
Exclamation 01 E38 Abs Locking Up????helllppp!!!!!
I recently had my brakes changed. Now the guy that did them I found after the job was done he clearly did not no what he was doing. The guy cut my sensors on the brakes and put together both negative and positive cables. Now I have the Brake light on, Abs light on, and the triangle light on the middle of the console on. Am thinking this idiot burnt out my ABS computer. I had all the sensors and ABS module replaced. The lights are still on and at times my brakes lockup while am driving. Am pretty sure am gonna now have to replace the ABS computer, but does anybody know if by me pulling the fuse on the ABS will this stop my brakes from locking up while am driving????
BimmerE38Man is offline   Reply With Quote
Old 02-26-2010, 07:57 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Ok dont panic, just the front brakes ??
Old 02-26-2010, 07:59 AM   #3 (permalink)
yes, its mainly the front brakes that are locking up.
Old 02-26-2010, 08:14 AM   #4 (permalink)
marti5's Avatar
Right whats happening is the ABS sensor is not reading the pulses, which occur as the wheel bearing rotates, to get you out of a muddle, remove both the front wheels (1 at a time it doesn't matter), then look straight ahead you will see a black rectangular box undo this and disconnect both plugs, ones for the ABS and the other is for pad wear, I'm not sure which one he's cut ...this will/should stop the brakes locking up, your lights on the dash will still be on until you replace the said sensors (whichever one he's cut).
The ABS one leads to the back off the hub, the other to the brake caliper (pad wear sensor), with the ABS one disconnected you will NOT have ABS (which isnt working anyway), but your brakes will work fine , so you can still drive normally.
PS. if you pull the ABS fuse your car will run like a bag of nails and be virtually un driveable
pps. after that go buy yourself a baseball bat and go play baseball with his head.
Old 02-26-2010, 09:13 AM   #5 (permalink)
thanks for your help you been helpful, next thing on my list is to play baseball with his head....lol
Old 02-26-2010, 03:10 PM   #6 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
<ale sure you keep an accurate score for posting here later. We want to hear about some good outta the park hits.
Old 02-27-2010, 10:07 AM   #7 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
dunno who replaced the ABS Module... but was it reset, and cleared for codes when installed?
If not, take out the guesswork, have the car scanned and it should tell you exactly where the ABS fault is.
How to install a remote central locking module on the existing central locking system SimonBalk 3-Series (E36) 12 10-15-2010 09:35 AM
My X5 is locking me out! Alicia B X Series 3 12-05-2009 09:37 PM
C/locking pkm3 Audio and Electronics 2 09-24-2005 02:35 AM
318is - Abs Light / Abs Pump Noise jonathan82 3-Series (E36) 0 08-31-2005 04:52 AM
Locking or non-locking differential an LSD? nick_g_evans 3-Series (E36) 3 03-04-2004 12:08 AM
