01 740i " module is not responding!"-w/carsoft ,,help - BMW Forum - BimmerWerkz.com
post #1 of 11 (permalink) Old 06-22-2009, 11:41 AM Thread Starter
bosanci28's Avatar
bosanci28 is on a distinguished road
Send a message via Yahoo to bosanci28 Send a message via Skype™ to bosanci28
i need to reset my airbag light ,,and i have the bmw carsoft 6.5 interface and cables,and soft,
i have tryed yesterday,,conection is okay,,
on the interface i have power on,,data light is blinking,,
but when i click to diagnose the srs ,airbag,,
i get :: modules does not respond :: (diagnostic port ,under the hood only i use 20 pic round)
i also have checked some other under diagnose but i get the same error to all,,module does not respond""!
so if there is a connection with the car ,,it maybe a module that is out,,and thats why i cant go thru to none of the modules on the car?
,,i was reading somewhere something about data crash,, this maybe something that it maybe in the way also?
i hade few engine lights soon ,,and i have reset them with a obd2 scanner in the car plug and it was fine,,
i purchase the car damage,,and i have fixed,,the airbag was out,,so i have replaced the airbag with a good one
,,check all fuses
,,under the hood i found 2 fuses from the airbag and thei ok (43,45)
does anyone knows why do i get that error,,
i really appreciate for any advice,,
thanks
bosanci28 is offline
post #2 of 11 (permalink) Old 06-23-2009, 06:08 AM
Help from over the pond
marti5's Avatar
You have got a bad connection, are you using a usb connector from you laptop if so this is probably the reason as they are very unstable you really need RS232 port. Just another thing do you have the key turned to position II.
marti5 is offline
post #3 of 11 (permalink) Old 06-23-2009, 10:11 AM Thread Starter
bosanci28's Avatar
the connection is ok,, and im using serial cable (no usb)
and i plug directly under hood at the 20 pin plug,,
key at position 2,,where all lights are on.
i have tested the cables ,,if i go in carsoft and change the settings port to nr 2 then a get a port com error ,,if i put back to port 1,and i click anything i will get the same error,,,,module does not respond,,
also im using a pc to car
thanks
post #4 of 11 (permalink) Old 06-23-2009, 10:30 AM
marti5's Avatar
Where did you get the software from, was it the one sent with the interface ?
marti5 is offline
post #5 of 11 (permalink) Old 06-23-2009, 10:36 AM Thread Starter
bosanci28's Avatar
the interface i have purchase without software,,
the soft i got it from some one on the other forum,,bimmmer..
but it runs ,, no errors ,,when i acces the car and i push anything,,or the srs diagnose,,i notice that the data lead on the interface is blinking,,so that means is working...
thanks
post #6 of 11 (permalink) Old 06-23-2009, 10:41 AM
marti5's Avatar
do you have the 16 pin lead ? as well as the 20 pin ?
marti5 is offline
post #7 of 11 (permalink) Old 06-23-2009, 10:47 AM Thread Starter
bosanci28's Avatar
yap i have a plug obd2 in the car and the 20 pin under the hood,,
but the interface come it only the 20 pin plug for under the hood.
from here
post #8 of 11 (permalink) Old 06-23-2009, 10:53 AM
marti5's Avatar
Damn!!, normally when they dont work in the 20 they work in the 16, sorry my friend I am unable to help you anymore, as I know from old that the facelift model does do this sometimes, try and get hold of a 16 pin, try Ebay.
marti5 is offline
post #9 of 11 (permalink) Old 06-23-2009, 10:55 AM Thread Starter
bosanci28's Avatar
thanks friend!!
post #10 of 11 (permalink) Old 06-24-2009, 06:01 AM
marti5's Avatar
I have read carsoft doesnt work with Windows 98, what you running on ?
marti5 is offline
post #11 of 11 (permalink) Old 06-24-2009, 11:12 AM Thread Starter
bosanci28's Avatar
win xp,,carsoft runs fine,
i have order that cable from the interface to obd2 in the car,,,to see if it works
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 1,6,7,8 - Series and Mini Cooper
2001 740i Sport "check engine soon" Chris Kethan 1,6,7,8 - Series and Mini Cooper 3 11-03-2008 02:26 PM
""*:·.-:¦:-·* 2001 330Ci MUST SELL ~ GREAT COND. $15000 ""*:·.-:¦:-·* bmwchic Cars For Sale 0 08-19-2008 01:36 PM
"key in ignition?" & "Lights On?" indicator DonMatmon 5-Series (E12,E28, E34, E39, E60) 1 12-01-2006 09:47 AM
1993 740i Motor "tick" While Idleing? robob69 1,6,7,8 - Series and Mini Cooper 2 10-07-2004 12:56 PM
